1990 Accord stops running
Old Dec 7, 2011 | 12:56 PM
racamponovo's Avatar
Default 1990 Accord stops running
My 1990 Accord will die in traffic but if I wait a few minutes, it will start right back up again. Any ideas? Two different mechanics have found nothing wrong with it.
Old Dec 7, 2011 | 06:05 PM
Have to figure things out when they are working...so don't blame them.
Any stored codes?
"Sounds like" a bad ICM, coil or key switch (elec part). Testing will be the key. Do you own a volt meter and or timing light?
Old Dec 7, 2011 | 07:34 PM
If you're still driving the car, take note next time the engine stalls.
1) Does the Check Engine Light come on when engine stops? It should. If not, the keyswitch assy is likely the fault.
2) When engine stops, turn keyswitch to On and listen carefully. You should hear a couple of soft clicks from under the dash, fuel pump in tank should buzz for 2-3 secs and cut off, and Check Engine Light should go off at same time fuel pump stops buzzing. If you don't hear these sounds, the Main Fuel Relay may be the problem. Most folks can hear these noises w/ careful attention.
jwood
Apr 2, 2012 08:32 PM
90accord90
Jan 25, 2010 03:28 PM
mchl_hoy
Sep 19, 2009 10:21 AM
bneweys
Aug 17, 2009 05:35 PM
MrT
Apr 25, 2008 08:48 PM
