1990 EX No Start
Old May 4, 2009 | 04:30 PM
I_Heart_My_4door
Question 1990 EX No Start
>Hello<
I have a 1990 EX (F22A4 5 speed), bone stock with a "no start" problem.
The car has 231,XXX on the orignal motor. It has a head gasget leak and burns a moderate amount of oil.
When it does run, it occasionally pulls a code 43 (Fuel delivery system) after being warmed up. Also at STOP signs and red lights the car will lose rpms and Idle rough.
The car WONT:
-Start everytime
The car IS:
-Cranking
-Getting Spark
-Intermitantly sputtering and starting
I HAVE:
-Replaced distributor, spark plugs, fuel filter and pump.
Ideas?
Old May 4, 2009 | 05:23 PM
Is your fuel pump turning on when you turn the key to the II position?
The pump will turn on an make a humming sound from the backseat area for about two seconds. Its a faint buzz/whirling sound, so you might have someone else turn the key and listen at the tank with the gas cap removed.
Old May 4, 2009 | 05:28 PM
Turn the key to ON but don't immediately turn to START. Listen for the fuel pump to run for 2 seconds then stop. It's not very loud, so have the radio & blowers turned off.
If the pump doesn't run, (matching the occasional non-start), it could be the main fuel relay. Search for "main relay" & you'll find all kinds of stuff. Can be fixed if you're good with a soldering iron.
Tony1M
Nov 6, 2023 08:29 PM
1990honda
May 7, 2009 11:49 PM
girlcrazy_4
Sep 26, 2007 07:00 PM
Mcgill224
Jul 12, 2007 11:27 AM
PedroG
Aug 6, 2006 03:25 PM
