1990 ignition and shifter sticks in cold
Old Oct 28, 2009 | 09:54 AM
phil068
Default 1990 ignition and shifter sticks in cold
I have a 1990 honda acoord that has developed a problem in cold weather. It started last winter, went away when the weather got warm but now is coming back on cold days. The ignition key goes in fine and starts the car, but it is very hard to get the key out. I can turn the car off, but the key wont rotate al the way back to release. Another problem is with the shifter. This is less frequent but sometimes it gets stuck in park and the shifter button wont release the shifter. I am thinking the 2 issues are somhow related but I am baffeled as to how this only happens when it is cold. If i drive the car for a long drive so it gets very warm inside the car the key comes out no problem? Anyone else heard of or experinced this problem?
Old Oct 28, 2009 | 01:31 PM
Something is wrong with the interlock system. It is designed to not allow you to remove the key until the car is in park.
There are several components that could cause a problem. Download a 91 shop manual via the online manuals link in the diy section. It will have the proper diagnostic procedures.
Old Oct 28, 2009 | 02:35 PM
TregoMark
I have the exact same problem with my 1989 accord LXi. I'll check the shop manual for the interlock system to diagnose.
Old Oct 29, 2009 | 12:37 PM
hondadude's Avatar
You might also consider getting a genuine Honda key
there is a plunger at the bottom of the lock cylinder, and if the key is worn or aftermarket it might not be pushing the plunger.
Old Oct 29, 2009 | 02:17 PM
deserthonda's Avatar
i had a couple of issues like that......it was the gear position switch located in the center console left side frt
denierlexiese
Aug 7, 2015 12:08 PM
mamtsberg
Oct 5, 2009 09:48 AM
cory43112
Nov 3, 2007 05:50 PM
gypsyman
Jun 4, 2007 05:39 PM
balance55113
Dec 19, 2006 08:53 PM
