1991 accord Lx clock not working right
Old Jan 16, 2009 | 10:02 PM
JTK's Avatar
JTK
Default 1991 accord Lx clock not working right
The clock in my 1991 Accord Lx will not keep time and comes on every now and then. I read something a while back about a bad ground but can't remember where. Any ideas on this?
Old Jan 17, 2009 | 07:19 AM
Default RE: 1991 accord Lx clock not working right
My Subaru clock was intermittent, and I removed the circuit board for a close look w/ magnifying glass. Others had reported problems w/ solder connections. Some surface mount resistors had cracked or broken solder joints. They are small and tricky to resolder, but can be done w/ a 25 watt pencil soldering iron and rosin-core electrical solder. This fixed my problem.
Bad ground is possible, but most likely the connector carries ground w/ a dedicated wire from a body ground point, so you would have to trace the ground wire back to it's ground point to clean/retighten.
A used part may be easier/cheaper. Check car-part.com for a part near you.
Old Jan 17, 2009 | 12:12 PM
f allen's Avatar
junk yard item, 5.00.
Frank Allen
Old Jan 18, 2009 | 02:50 PM
JTK's Avatar
JTK
Thanks for the replies. I tried a different clock from another 91 accord and had the same problem. I can't remember where but I remember reading something about a relay or a box of some kind under the dash that will cause this. I don't have a harness diagram or a helms to trace the wires.
Old Jan 18, 2009 | 03:49 PM
This result suggests the male connector to the clock probably has a damaged or weak connection pin, most likely the D pin (lower left pin when looking at connector w/ latch to top). The leads to the clock are always-on power D(time memory), switched power C (display), ground B, and lights-on signal A.
Damaged wire or poor ground are also possible, but probably less likely that a bad connector.
Pins arrangement looking at connector w/ latch to top:
C B
D A
You may have to find a new connector to splice/replace existing connector. I believe Honda can supply replacement connectors.
joshh
Jan 3, 2014 10:56 AM
WindPhoenix
Aug 10, 2012 10:15 PM
poisonshift
Nov 29, 2011 11:13 AM
old88dog
Jun 13, 2007 10:58 PM
doctorpowder
Sep 12, 2006 11:26 PM
