1991 Accord overheating on idle
Old May 7, 2012 | 06:42 PM
ryno619's Avatar
Default 1991 Accord overheating on idle
hello new to the forum... ihave a problem i recently bought a 1991 accord and been noticing it gets hot when idling but as soon as the car starts moving the temperature goes down.... i have already replaced the thermostat, the cooling fan switch on the thermostat housing and the switch at the end of the upper radiator house that leads to the head... the fans come on while the car is on and after i turn it off... i don't think its the head gasket as the car runs too good for that and i have never got that smell of water and oil mixing... pls let me know what i can do thanks in advance
Old May 12, 2012 | 01:42 AM
Tyler Joyce's Avatar
Old May 12, 2012 | 08:58 AM
It is possible that cooling system is not completely filled and causing overheating. Bleed air from bleeder valve on top of engine to insure no air traps preventing coolant circulation.
If cooling system is filled, fans don't come on w/o AC and car overheats, then either fans are faulty (you said they run sometime, not clear when), bad fan relay (fans run sometimes?), faulty thermoswitch A (on the thermostat housing), or if fans are running and car overheats the thermostat is faulty and needs replacement.
Old May 13, 2012 | 10:31 AM
ryno619's Avatar
Sorry ill post in the correct forum next time... my first time posting here
Old May 13, 2012 | 10:35 AM
ryno619's Avatar
Thank you very much... it was exact problem I was bleeding the wrong way... I learned the hard way after replacing parts that didn't need it... thanks again for the help
CB7-SE-1991
Jan 29, 2013 04:45 PM
paulmezick
Jan 10, 2012 07:19 PM
dpc386
Aug 9, 2011 10:34 AM
d_10
Jun 27, 2007 10:01 PM
Joshporsche
Jun 14, 2006 10:07 PM
