1991 Accord Won't Start
Old Aug 6, 2011 | 07:57 AM
steve1991accord's Avatar
Default 1991 Accord Won't Start
Yesterday evening the car ran fine. This morning I put key in ignition and get normal chimes, etc. Turn the ignition and suddenly nothing. Horn, gauges, are completely dead. Trunk light does work.
Battery is fully charged. Cables are tight. From the behavior I assume it is a (master) fuse of some sort.
Any ideas?
Old Aug 6, 2011 | 08:38 AM
Suggest removing and cleaning each battery cable first to be sure there's not some corrosion in the clamp preventing current flow. Check starter and ground connections also. If those are good, trace voltage to the underhood fuse box fuses and onwards. Somewhere there's a bad fuse or loose connection.
It's also possible that ignition switch assy has gone out. I've never head of one failing quite so completely at once, but it may be possible. If all battery wires, fuses check out, then ignition switch seems likely.
jmalek
Nov 7, 2011 11:24 AM
Lch05Srm
Aug 21, 2011 11:27 PM
MadNoys
May 11, 2009 03:06 AM
squintv
Jan 23, 2009 11:07 PM
philtrim
Oct 21, 2008 02:01 PM
