1991 accord won't start
Old Jan 22, 2009 | 07:59 PM
squintv
Default 1991 accord won't start
OK, so I have a problem like the other guy, only it is the fuel side. Its a really odd one to me.
I initally thought it was spark related because i was checking for a bad cylinder, so i pulled the plugs one at a time, while i had the plug wire pulled off, it arc'd on the valve cover a bunch and the car died. i thought it was surely an ignition problem, so i hooked up the timing light, and every wire is getting fire. so i thought it was a fuse connected to the computer or something, i found a blown fuse and replaced it, stillnothing. so i loosened the fuel line, and turned the key and it sprayed out! so im down to the injectors i think.
but the odd thing is i sprayed ether into the intake and it didn't fire at all, so could the wires not be firing even though the timing light is picking something up?
Old Jan 22, 2009 | 11:32 PM
Default RE: 1991 accord won't start
Replace the spark plugs if they are due. What fuse was blown?
One wire (all the same color) going to each injector should have 12V when the key is in the II position at all times. Test that each wire has 12V.
The other wire gets grounded by the ECU to open the injector. The resistance across on the two terminals injector should be the same (2.2 ohms I think).
If you have a 12V test light, unplug an injector and attach the light across the plug. When you try to start the car, the light should flash on each injector.
Let us know what you find.
Old Jan 23, 2009 | 11:07 PM
squintv
I just went ahead and replaced plugs wires cap and rotor, and it fired right up..
jmalek
Nov 7, 2011 11:24 AM
Lch05Srm
Aug 21, 2011 11:27 PM
steve1991accord
Aug 6, 2011 08:38 AM
MadNoys
May 11, 2009 03:06 AM
philtrim
Oct 21, 2008 02:01 PM
