1991 Wagon LX - quick valve cover gasket question
Old Apr 1, 2009 | 10:27 PM
hamandcheeseonrye's Avatar
Question 1991 Wagon LX - quick valve cover gasket question
I think I'm pretty comfortable with what I need to do to replace the valve cover gasket and plug seals on my wagon. I have the part but it's made by Stone, not Fel-pro like most people seem to recommend. The guy at the place I bought it said I don't need anything like Honda bond because its rubber. Is this right? Almost every post I've read on here about this talks about using a little honda bond at the bends of the gasket. How bout the plug seals? Anything I should know there? Sorry for the total novice questions but I've wanted to learn to maintain my cars myself for a while and this old wagon seems like a decent one to learn on.
Old Apr 1, 2009 | 11:36 PM
finch13's Avatar
You may not need an extra sealnt for the gasket... but you don't need to get Honda Bond either. Go back to the auto parts store and look for something like "RTV silicone" or "silicone gasket maker". Apply that to the corners and you should be leak free!
Also, Stone should be fine, if it doesn't leak it's doing it's job!
Old Apr 2, 2009 | 07:15 AM
Pay attention to the shape of the upper plug seals. Don't put the new ones in upside-down.
Permatex Ultra Grey is the stuff that's closest to HondaBond.
At the ends, where the gasket goes over the camshaft caps, there's 2 sharp corners at each end. That's where to use the sealant. Just a little bit in each corner.
If you have oil leaking into the spark plug tubes, there's a chance that it's coming from the lower seals, which are like O-rings further down. You have to remove the camshaft bearing caps (along with the valve gear), so that's a bigger job. Maybe leave them alone & only do them if it keeps leaking.
poynterandy
Jul 25, 2011 05:44 AM
ctconline
Aug 8, 2010 04:08 PM
thunder_x
Jul 9, 2007 11:57 AM
richomundo
Mar 13, 2007 09:25 PM
PIGGEBANK
Aug 13, 2006 12:13 AM
