1992 Honda Accord Will Not Start
Old Sep 11, 2007 | 10:42 PM
steve55121
Default 1992 Honda Accord Will Not Start
I have a problem with my 1992 honda accord lx. I was very low on gas and heading to the gas station. 2 blocks away from the station I ran out of gas. After adding a few gallons of gas to my Honda I'm unable to get it started. The car appears to be turning over fine. I can hear the fuel pump engage. I can even smell the gas when I get impatient in trying to get it started. I had a issue with the main relay. That has been fixed in the parking lot where its currently sitting.
So far I have changed the main relay and the fuel filter. What should I check next??
Thanks.
Steve
Old Sep 12, 2007 | 12:36 AM
Default RE: 1992 Honda Accord Will Not Start
With no starts, you need to determine if there is lack of fuel or spark.
There is an excellent writeup on www.tegger.com/hondafaq/faq.html for starting problems.
You can ground a spark plug and turn the engine. If you see a bright blue spark, then the spark is fine.
For fuel, you can spray some starting fluid in the intake and see if the car starts up for a second. If it does start then dies, then I would get the fuel pressure tested.
Accord2113
Jul 18, 2011 10:11 PM
partsman1
Nov 5, 2010 07:25 PM
ruanddu
Aug 20, 2009 04:01 PM
LuvMyHondas
May 26, 2009 08:41 PM
fperezal
Jun 14, 2006 05:03 AM
