1992 A/t Accord No start
Old Jul 14, 2011 | 07:55 PM
Accord2113's Avatar
Default 1992 A/t Accord No start
Alright so heres the problem, my accord stalled and wont start back. The problem is with the ignition, the cel code was 8 wich is the tdc sensor so i got a used distributor from the scrap yard and the only spark i would get comming out of the coil was just when i was releasing the key from the start position... So again went back and got a used distributor seing that the one i just bought was defect ... again with the same problem the spark was just at the end ... so now im confused could it be something els or i was just unlucky and got 2 bad distrubutors with the tdc (top dead center) sensors not worcking ... im just wondering if ne one could help me out and if theres a way to get a free wiring diagram for the ignition with a way to test the problem. Could it come from somewhere else or would i be better off spending the money and risking the new distributor.
Thanks in advance.
Old Jul 14, 2011 | 09:53 PM
A quick test would be to check for 12V going to the blk/yel wire of the distributor or coil when the key is in the II position.
The Common DIY Threads (second thread in the gen tech help forum) has a link for shop manuals. I think one for the 91 will work on your car.
Old Jul 15, 2011 | 05:15 PM
Accord2113's Avatar
Ya ive checked my 12v and its there i got a new distributor bu the fire only sparks out of thecoil when i release the key
Old Jul 15, 2011 | 05:43 PM
Is your coil inside or outside of the distributor?
Old Jul 15, 2011 | 07:32 PM
Has the TDC (code 8) gone away or returned?
Old Jul 18, 2011 | 06:08 AM
Accord2113's Avatar
Its outside but ive tried putting a new one and still nothing im thinkin it has to be a cut wire somewhere thats not sending in the right signal.
Old Jul 18, 2011 | 09:09 PM
Accord2113's Avatar
Ya it did but like i said ive changed the distributor with a brans new one and still no start. Is neone aware if there is a wire of some sort that passes over the exhaust heat shield cuz mine was loose so i screwed it back maybe i hit a wire of some sort
Old Jul 18, 2011 | 10:11 PM
Tek310's Avatar
re-trace your work. make sure no wires are wedged.
its late have school at 7am. if your question is not answered by tomorrow i will get you a wiring diagram
or you can download a shop manual. the link is in the DIY section
crw
Apr 10, 2012 06:33 PM
partsman1
Nov 5, 2010 07:25 PM
ruanddu
Aug 20, 2009 04:01 PM
LuvMyHondas
May 26, 2009 08:41 PM
steve55121
Sep 12, 2007 12:36 AM
