1993 cv axle question
Old Jan 16, 2015 | 08:09 AM
Rdellar's Avatar
Default 1993 cv axle question
I have found conflicting information on whether I can slide the replacement cv axle thru the dogbone/wishbone when replacing it, only needing to remove the ball joint and upper control arm to move the brake rotor/caliper out. I bought the car from a person who replaced the cv boot because it was blown, but I feel that the sound it makes when turning means I should just replace the axle. He replaced ball joints on both sides and did the brakes so everything is in good shape and shouldn't give me much trouble freeing it up. Also heard there is slight difference between orm Honda cv axle and aftermarket parts regarding the clearance thru the wishbone. I am mechanically inclined and will be doing the work myself. If anyone has any suggestions on the best parts for the right price I am listening also. Thanks for your help.
1993 accord dx 5 speed
Old Jan 16, 2015 | 03:57 PM
I've managed to install CV axle w/o removing the wishbone but boot had to be squeezed a bit. Removing wishbone is not that difficult.
No idea about dimensions of CV boots on OEM and aftermarket. They looked same to me.
Old Jan 17, 2015 | 07:29 AM
MikeT's Avatar
The "aftermarket" are just the stock ones rebuilt with new bearings. The dimensions should be the exact same.
Old Jan 18, 2015 | 01:07 AM
Rdellar's Avatar
Thanks. I will post a pic and description after the work is completed.
Old Jan 18, 2015 | 06:27 AM
Turtlehead's Avatar
I have never had any issues with them.
accord_li
Dec 12, 2024 07:02 PM
gfam
Apr 19, 2012 08:48 AM
93Accord2.2
Jan 11, 2012 07:03 PM
faosh
May 27, 2008 12:03 PM
nixalot
Jan 25, 2007 02:02 PM
