1994 ACCORD sputtering and stalling
Old Feb 20, 2011 | 05:32 PM
8lug's Avatar
Unhappy 1993 ACCORD sputtering and stalling
Hello all. Got a 93-2.2 Lt. Accord with 324,000 miles sputtering and stalling. I have no check engine light and no codes being thrown. I have cleaned the oil out of the plug chambers and put a new valve cover gasket with the spark plug O ring gaskets. I have also put new NGK plugs,wires,distributor cap and rotor and still have this problem. I don't seem to have any vaccum leaks. I'm confused on what to do next !! I hate to keep throwing parts at this thing !! Does this car have an EGR valve on it and could this be the next thing to check or clean ?
Old Feb 20, 2011 | 06:17 PM
You may have a bad coil or ignitor. Check techauto.awardspace.com for info on diagnosing these parts.
Check new distributor prices before replacing coil and/or ignitor.
Old Feb 20, 2011 | 07:50 PM
8lug's Avatar
Cool
Thanks TexasHonda I could not get the site to come up it kept timing out. I did find Easy Auto Diagnostics.com with a very good wright up on how to diagnose the entire distributor ignition system with pictures and basic tools. From researching this site I believe it could be the igniter or position sensors as I have already replaced the plugs-plug wires-rotor-and distributor cap. I will do these tests and post what I find.
Old Feb 21, 2011 | 10:32 AM
8lug's Avatar
Well it turned out to be the ignition control module. New one in and running smooth and strong !! Thank you for putting me in the right direction Texas Honda !!
Brian Humek
Jan 22, 2014 10:25 AM
Samanthadd
Sep 20, 2013 10:14 AM
crashdummie
Aug 14, 2013 07:35 AM
Bleedinpurp
Mar 31, 2013 03:17 PM
TroopRex
Dec 12, 2011 12:47 AM
