1994 Accord Starting Problem
Old Oct 30, 2013 | 01:55 AM
Ryan Boswell's Avatar
Default 1994 Accord Starting Problem
Okay i have a 94 honda accord. It will push start. But wont start with the key. battery gets 12.7 volts. the starter is brand new. i have great connection from battery to starter. although on my car the clutch button does not go in do to not having a whole in the clucth pedal where that goes threw. i was told it could be a wire from the starter to the ignition but idk. im at a loss here. what do i do
Old Oct 30, 2013 | 06:46 AM
Moved your post to a new thread for better attention. Generally best practice is not to append a new problem to an old post, even when problem is related to original thread.
Check small Blk/Wht wire to starter solenoid for 12V when keyswitch is turned to Start. If 12V missing, then something is interupting the starter signal; ignition switch assy, clutch interlock switch, or starter relay. Check for 12V at starter, relay, interlock switch to find the culprit.
Not sure of your meaning about interlock switch, but jumper it w/ wire bridge to see if that fixes the problem.
opaque
Apr 22, 2013 12:17 AM
JimboBigLotto
Jul 2, 2011 01:46 PM
george3405
Feb 25, 2011 08:28 PM
hondas only
Aug 31, 2007 09:05 AM
joeeeee
Jun 27, 2007 10:30 PM
