1994 EX automatic
Old May 28, 2017 | 01:46 AM
Phi.mtruong's Avatar
Exclamation 1994 EX automatic
Symptoms:
-non-funcitonal speedometer
-D4 gear selector blinking
-harsh/delay shifting
-can't get into higher than 2nd gear
-odometer non-finctional
-erratic iddling
-idle surges when in park or neutral
I've switched out the Transmission output speed sensor like a lot of peopel suggested. But that did not solve the problem. Could it be the VSS as well?
Also, when I googled output speed sensor and input speed sensor, they look exactly the same. Is there actually a difference? And is output speed sensor the same as main shaft speed sensor?
Old May 28, 2017 | 06:05 AM
What code(s) are you getting from the "D4" light?
Old May 28, 2017 | 06:08 AM
I didn't get any code at all, even though the check engine light and ABS light come on occasionally, only when I'm driving.
Old May 28, 2017 | 06:21 AM
So when you jump the service connector on the pass side the CEL, D4 and ABS lights do nothing?
Have you tested the VSS?
Old May 28, 2017 | 02:46 PM
The lights didn't do anything. I checked the paper clip to be sure but nothing. I checked the connecor to the VsS and that's good. How do i check the VSS itself?
Old May 29, 2017 | 06:00 AM
There are three wires to the VSS. Start with testing;
BLK - continuity to ground
YEL - battery voltage
ORN - should be around 5v
Still find it strange you are getting "nothing" when you short/jump the service connector.
faran
Aug 1, 2016 06:07 PM
honda-fan
Jun 26, 2014 10:00 AM
swingkid50
May 20, 2012 09:29 PM
covered
Sep 20, 2011 07:14 AM
Ronnie101
Jun 21, 2007 09:44 PM
