1994 ex clutch squeak
Old May 15, 2012 | 06:34 PM
michael6593's Avatar
Default 1994 ex clutch squeak
I've been noticing lately that everytime my car warms up, it seems to squeak when i engage the clutch. I've also noticed it like whenever there is pressure on the clutch. I have no idea what it is. any help is appreciated!
Old May 15, 2012 | 06:59 PM
bump bump bumpitty bump
Old May 15, 2012 | 07:02 PM
I would suggest that you don't bump after posting 30 minutes ago.
Can you tell us where the squeak is coming from?
Old May 15, 2012 | 07:06 PM
my bad. and thats my problem, i have no idea. it sounds like its by the clutch pedal. i probably sound really stupid.
Old May 15, 2012 | 07:09 PM
ill post a video in a little bit.
Old May 15, 2012 | 07:13 PM
It would help if you found an assistant to push the clutch pedal. Open the hood and try to find the area where the noise is originating.
When you sit in the car, the location of the noise inside the car can be hard to determine.
Old May 15, 2012 | 07:15 PM
Check the pivots on the clutch pedal, grease em if needed.
The clutch slave cylinder is bolted to the engine/transmission, kinda mid-elevation between the engine & radiator. It's piston rod presses against the throw-out lever. That piston is kinda like a ball/socket, so put some grease there.
The throw-out lever itself is hinged on a ball/socket inside the bellhousing. You may not be able to reach in & get grease on that, but you can try. Just don't squirt grease all over in there, because you DON'T want to get grease/oil on the clutch itself.
The throw-out bearing slides on a sleeve around the transmission input shaft. You can't reach that, but it's maybe the more likely thing making the noise.
Old May 15, 2012 | 08:33 PM
thanks for all of the replies!!! --this only happens when im driving, and there is pressure on the clutch. here is a video of it happening you can faintly hear it.
Squeak - YouTube
Old May 16, 2012 | 01:48 PM
bump bump
Old May 16, 2012 | 02:06 PM
crispin's Avatar
bump bump
Please don't do that.
Have you followed the suggestions of Jim and PA Honda yet?
AccordCroz
Apr 19, 2007 04:56 AM
watut
Mar 3, 2007 02:47 PM
tamb
Jul 21, 2006 01:05 AM
94exsedan35094
May 20, 2006 04:37 PM
GroceryGettr
Nov 29, 2005 04:47 AM
