1994 Honda Accord EX Idle dips
Old Nov 18, 2016 | 10:07 AM
nathan1228's Avatar
Default 1994 Honda Accord EX Idle dips
Hello everyone, I have a 1994 Honda Accord and I have a question about the idling system. Anytime i sit and have the car running it will be idling fine and then there will be a sudden dip in the rpm's (down to about 250) and then it will go back to its average idle rpm (about 750-900). I took the car into AutoZone and the guy there told me it was the beginning of my transmission going out. Just came to this forum to see what you guys have to say and if I can believe this guy. Any input would be greatly appreciated. Thank you!
Old Nov 18, 2016 | 10:14 AM
It's likely a dirty throttle body and idle air control valve (IACV). Cleaning is fix.
When load (alternator or AC compressor) is added IACV should open to allow more air and increase idle speed to avoid too low rpm. A dirty throttle plate and IACV will block the air flow.
Old Nov 18, 2016 | 10:17 AM
nathan1228's Avatar
How easy are these to clean? and where could i go to get a reference on how to clean them?
Old Nov 18, 2016 | 10:23 AM
Check DIY forum for previous posts on the subject. Check youtube for videos. Similar repair for Accord 4-cyls from 1990-2002.
You can clean throttle plate and bore in place by removing air intake. IACV must be disconnected from throttle body (tight access on back side of throttle body). Leave coolant lines intact and clean in place w/ throttle body cleaner.
Old Nov 18, 2016 | 10:34 AM
nathan1228's Avatar
Thank you very much for the reply and your insight, much appreciated!
inkuyo
Oct 8, 2012 12:34 PM
alphamoon70
Aug 26, 2011 12:05 PM
rwsandman007
Dec 29, 2008 02:18 AM
huzzsaba
Jan 8, 2007 04:42 PM
beaterhonda
Jan 6, 2007 10:40 PM
