1994 honda accord ex with issues
Old Oct 15, 2011 | 05:53 PM
jessiejojoe's Avatar
Default 1994 honda accord ex with issues
Hi yall, I'm new at this so please bear with me. I have had my 1994 Honda Accor EX for 9 months. After I bought it the transmission started slipping. It does it really bad when going up hills from a stand still. It goes up hills fine as long as i have a little speed behind me. It revs up really bad when you touch the gas after slowing down to turn. I just needed to see if there was anything else besides the transmission that would cause this problem.
Also, just recently it stared doing some strange stuff with the electrical. for a whole week every time I started the car up the windshield wippers came on and would stay on unles i left the door ajar. Now that problem has quit(for good I hope), my brake light wont go off. I dont know much about cars and I dont have much money to spend so any advice would be greatly appreciated!!
Old Oct 16, 2011 | 07:47 AM
Not much for the trans....check fluid level, last changed? Pretty odd for this gen (94-97) to have issuese but the do happen. If it is bad, a used one with low miles might be an option-weigh the options and cost.
For the brake lights, check to be sure the "plug/stopper" for the brake light switch is still there. Common issue is that plastic stopper will break after ~10 years...they are ~$4 at the dealer...46505-SA5-000 is the part number at the dealer.
If the plugs is there and making contact with the switch, test the switch.
Old Oct 16, 2011 | 12:08 PM
thanks for the advice. the brake light went off today. guess I'll wait and see if it comes back on.
After I bought the car I had the transmission flushed and the filter changed. I was better for about 4 months then started slipping again. I may take your advice and get a used transmission, definitly the cheaper way to go. Thanks again!
Old Oct 16, 2011 | 12:17 PM
Wait, read wrong I guess.....this brake light, is this on the dash-if so which one-like the e brake is on or the one at the back of the little car icon (telling you the door is open).
Old Oct 21, 2011 | 03:44 PM
its a red light that says 'brake'
Old Oct 21, 2011 | 06:40 PM
bigpat's Avatar
Almost A Senior Member
Dash indicator light for parking brake...?? Maybe the switch in the handbrake is the cause...
Old Oct 21, 2011 | 10:10 PM
Please check the brake fluid level. Frngs.om there, there are other thi
Ineedhelp
Jan 22, 2012 07:29 PM
BSmoov83
Dec 20, 2011 06:02 PM
giffster792
Jul 10, 2011 09:38 AM
HondaAccordKid
Oct 25, 2010 06:41 PM
GOT BOOST
Nov 2, 2009 08:32 AM
