1994 Honda Accord Lx w/ h22a wont start
How's it going Honda Accord Community. I have been a honda guy for awhile but I have just recently traded my bike for a 94 Accord with a H22A swap. For the first couple months the car ran fine but then it began to take awhile to start up. It would continue to crank and eventually turn over and start. Regardless, one day it decided it didnt want to start. When I turn the key all the lights, radio and other electrical components turn on but the engine refuses to turn at all. The first thing I checked was my battery and it was good. Then I moved on to replace the starter and the ignition switch and nothing has changed. Unfortuantely im at a point where I dont know what to do.
Thanks for your help,
Sirbobert
Sirbobert
First thing to check is the clutch switch. This assumes you have a manual car. If not then you might want to check the neutral safety switch.
One of the common mistakes of this swap is that they forget to swap pins A6 and A11 if using an obd1 p13 ecu. Obviously I'm not sure what ecu you have.
