1994 Honda Accord Slams into Drive or Reverse
Old Aug 15, 2012 | 06:44 PM
What is the engine RPM when this happens?
Old Aug 15, 2012 | 06:53 PM
gabrielbyrnei's Avatar
RPMs are ok, around 800-900 on park and a bit lower on drove, maybe 800
Old Aug 15, 2012 | 10:21 PM
Again if there is a "slam" then I'm back to the mounts......the rpm's given are within range.
Old Aug 16, 2012 | 09:11 AM
But if the problem was a mount, it would happen both on cold engine temperatura and hot.
It only happens on hot, hence my assumption its the ATF+4 thins out too much on hot operation?
Old Aug 16, 2012 | 06:53 PM
Could be, there is no harm to do another drain and fill with the Honda fluid. I'd get enoguh for a third if needed...plus sometimes you can "deal" on larger quantities.
MessAround
Dec 3, 2013 12:48 AM
Rammstein001
Mar 12, 2011 10:36 AM
yhalabi
Aug 21, 2008 06:40 PM
yhalabi
Aug 19, 2008 07:45 PM
yhalabi
Aug 17, 2008 04:04 PM
