1994 LX rpm surging after driving, only in park
Old May 16, 2012 | 02:56 PM
Lucyy's Avatar
Exclamation 1993 LX rpm surging after driving, only in park
Hey,
My 1993 LX Is having issues. The car is surging between 1000 and 1500 rpm but only after its been driving and set in park, not in any other gear. Cleaned out the iacv and checked to adjust the fitv and replaced my pcv and new hose. I suspect that my oxygen sensor is also bad could this cause my surging issues? What else could I check?
Old May 16, 2012 | 03:00 PM
Have you checked the radiator coolant level? Wait till it cools down, and open the radiator cap to check. If it is low, add a mix of 50/50 coolant/distilled water. You may need to also purge any remaining air pockets in the cooling system.
Old May 16, 2012 | 03:04 PM
Lucyy's Avatar
Yeah, checked coolant levels were normal
Old May 16, 2012 | 07:05 PM
Vacuum leaks, loose FITV, and incorrectly adjusted idle can cause that too. Look in the DIY area for a post by me about setting the BASE idle.
Old May 16, 2012 | 07:17 PM
GoneHonda's Avatar
sounds like a vacuum leak my friend, you can get a can of starting fluid and spray your various vacuum hoses and connections and if it jumps up in rpms right away then there is a leak.
Old May 17, 2012 | 11:50 AM
Lucyy's Avatar
I got some starting fluid and checked my hoses but I can't seem to find any leaks.. In gonna try cleaning out my iacv better and check again for a leak.. Any suggestions on my next step?
Old May 17, 2012 | 12:51 PM
Dr. Drivability's Avatar
intake manifold gasket leak...since it happens after you've been driving and it's warmed up...and no, O2 sensor won't cause your problem. spray around the intake runners at the cylinder head.
Old May 17, 2012 | 03:05 PM
Lucyy's Avatar
Any posts here breaking the job down?
Old May 17, 2012 | 09:16 PM
Just me but check/clean the air boost valve on the end of the TB- Drivers side.....
EDIT: Title says 94.....text in message says 93- my answer is to the 4th gen......94 vs 93, different gens so PLEASE let us know which it is.
Old May 17, 2012 | 10:55 PM
Lucyy's Avatar
Woah my bad it's a 1993
800rmk
Jun 3, 2020 06:02 AM
94_Accord
Jul 30, 2013 09:49 PM
campervan12000
Jun 15, 2011 07:23 AM
mag1
Aug 15, 2007 01:01 PM
acidflux
Oct 15, 2006 06:53 PM
