1995 Accord 2.2 (non-vtech) CEL code 12
Old Jun 23, 2011 | 08:08 AM
skeebs's Avatar
Default 1995 Accord 2.2 (non-vtech) CEL code 12
I desperately need help resolving this code so I can get my state inspection and emissions testing by the end of this month.
I've swapped out the EGR valve, cleaned the EGR ports/passages, cleaned the intake and IACV, all the vac & emission lines (that I can see) look to be in good condition. Still throwing the code.
Any advice on what else to look for or clean would be greatly appreciated.
Thanks!
Old Jun 23, 2011 | 02:13 PM
Open the Common DIY Threads post stickied at the top of this forum. The online manuals thread has a 94 shop manual you can download. The fuel an emissions section has the steps to diagnose a code 12.
Old Jun 23, 2011 | 02:41 PM
I did a fast seach on the code and #12 says EGR lift sensor malfunction or circut fault..look those 2 up while your in there..
Old Jun 23, 2011 | 09:16 PM
Tek310's Avatar
check to make sure your vac hoses to the egr valve are good and there is no leak.
pull the 7.5a fuse labeled back up to clear codes and test drive.
also make sure the egr gasket is sealed and not leaking
Old Jun 24, 2011 | 12:39 PM
skeebs's Avatar
Thanks for the replies everyone. I'm still learning to navigate around this forum to find all the pertinant info, my apology. If I had found those shop manuals previously...it would have helped
Anywho, it seems one of the two are possibly junk...the EGR control selenoid valve or the EGR vacuum control valve. I cleaned them up, pulled the fuse to reset, follow the idle procedures and what not. Then test drove last night and drove to work this morning (roughly put around 40 miles or so) and the CEL has yet to pop on. Let's pray that did the trick.
Old Jun 24, 2011 | 05:06 PM
Tek310's Avatar
glad to be of assistance, good luck.
Old Jun 27, 2011 | 10:22 AM
skeebs's Avatar
It did do the trick! WOO HOO Glad you all jumped in to help. Drove it all weekend & the CEL has yet to come on since I cleaned those two items. I was able to pass my state Inspection & Emissions tests this morning. My $600 DD is good to go for another year
localstoner
Oct 25, 2013 05:56 PM
firefunk
Nov 27, 2011 02:15 PM
biglfla
Nov 29, 2010 07:58 PM
92accordDX
May 3, 2008 08:57 AM
bil6ly05
May 21, 2007 10:55 PM
