1995 Accord Engine Shaking After Cooling Fans Turn On.
Old Jun 7, 2005 | 12:51 AM
Fredi95EX
Default 1995 Accord Engine Shaking After Cooling Fans Turn On.
Hello,
I have a 1995 Accord EX with 105,000 miles. Every time the 2 cooling fans engage, the RPMs drop low enough to cause the engine to visibly shake (almost stall). Please help. Thank you
Old Jun 7, 2005 | 03:00 AM
Default RE: 1995 Accord Engine Shaking After Cooling Fans Turn On.
Hi Fredi..
I'm thinking that your fuelpump is not delivering sufficent fuel to the fuel injector system.
I would start by checking that 1st...
Old Jun 7, 2005 | 12:09 PM
Evlampius's Avatar
I dont know man,
I'd check the electrical charging system first.
Old Jun 7, 2005 | 01:47 PM
Alekat's Avatar
Usually the 2nd fan is only engerized when the A/C is on. Compressor engagement usually increases the idle speed. Could be that: the A/C system is not functioning properly in conjunction with the fuel system.
Old Jun 7, 2005 | 02:47 PM
Fredi95EX
The A/C was on at the time. Hopefully it won't turn out to be anything major. Thanks Guys for your input
Old Jun 8, 2005 | 12:30 AM
Fredi95EX
Default RE: 1995 Accord Engine Shaking After Cooling Fans Turn On. A/C Overcharged???
I recently had my A/C system recharged at a shop. That's when all these strange symptoms started. I released A LOT of pressure from the system, but left just enough for the A/C to keep functioning. Now the car is now running fine when the A/C is on. The idle is actually consistent now. Before, there would be a single "bang" coming through the High Pressure A/C line before the cooling fans turned on, and then the idle would drop immediately. I'm thinking the system was overcharged. Thanks
Old Jun 9, 2005 | 12:38 AM
Evlampius's Avatar
great! i'm happy that it solved the problem
Old Jun 14, 2005 | 03:19 PM
accordlowered04's Avatar
glad that your problem is solved. my motor messed up on my cooling fan. not a cool thing. someone let me know what could have caused this.
Old Jun 14, 2005 | 10:40 PM
Evlampius's Avatar
ummmm......witchcraft!!! I think you've been cursed, my friend!
Old Jun 16, 2005 | 11:07 AM
i got it fixed. paid 80.00 for a new motor and made my dad put it in.
blueeguardian
Dec 30, 2014 09:13 PM
mishakol129
Apr 7, 2013 06:48 AM
POS-Accord92
Jan 5, 2012 11:14 PM
Honda1PR
Dec 6, 2010 11:27 PM
1stchild
Sep 14, 2007 04:15 PM
