1995 Honda Accord EX 2.2L V-Tec MT will not start
Old Jun 25, 2012 | 08:01 PM
Ron@honda95's Avatar
Default 1995 Honda Accord EX 2.2L V-Tec MT will not start
I have a 1995 Accord EX 2.2L V-Tec MT will not start util the check engine light goes out and the fuel pump comes on. Key in the on postion It takes 15 minutes most of the time. Shorted sevice port for Check engine light codes, Light stay on and dose not blink is this a 0 ? Looked on internet for list of codes the list said 0 and 11 was the ECU knot sure if this is right. I pulled backup radio and ECU fues to reset ECU did not help still had to whait for check engine light to go out. I Also have replaced the main relay. Do i need to replace the ECU ?
Old Jun 25, 2012 | 08:39 PM
Did you short the service connector to check for codes? See the common diy thread on top of the gen tech help forum. There is a link in there on how to check engine codes.
Old Jun 25, 2012 | 09:02 PM
my1st.honda93's Avatar
you see i did not know that!thank you PAhonda! this is why i read more replys than i ask questions,you can learn more by just reading then asking!
Old Jun 26, 2012 | 03:06 PM
Yes i did check engine light stayed lit on flashing.
Old Jun 26, 2012 | 06:41 PM
The ECU turns off that check engine light, so replacing the ECU would be my next guess.
BCBoy
Jan 12, 2015 12:33 AM
martinez289
Mar 1, 2013 06:33 AM
funkyguy
May 17, 2012 09:46 PM
jitterjuice
Jul 27, 2011 07:55 PM
Custnam
May 6, 2008 10:40 PM
