1995 Honda Accord EX: ABS Cover
Old May 12, 2012 | 03:34 AM
Joseph97297's Avatar
Default 1995 Honda Accord EX: ABS Cover
Hello all. Have a 95 Accord Ex, pushing 350 thou on the odometer and trying to head off an issue.
The ABS cover, the plastic top that you fill the ABS reservoir with, is starting to dry rot. It isn't too bad yet, but I can see where it will be an issue within some time. Any ideas or opinions?
Just this year did the timing belt, all new hoses and such, and car looks and runs fine now. Just wondering if this a locatable part, or am I going to have to purchase a whole new reservoir? Thanks.
Old May 12, 2012 | 07:45 AM
The abs reservoir is easily replaced. I don't know if it's an available Honda part, but there are many good used parts available.
The reservoir may only be replaceable after removing the modulator. I removed mine w/ modulator off, so don't know if it can be done in place. Removal of modulator is a 15-min job.
For a used part, you will likely have to buy the modulator to get the reservoir, but modulators are readily available for $25-$50. Check ebay and car-part.com for parts.
Old May 12, 2012 | 08:54 AM
Are you talking about the "black rubber" cover? Under that is another "clear" plastic plug - or there should be.
Attached Thumbnails 1995 Honda Accord EX: ABS Cover-5th-gen-abs-parts-list.jpg
nitishnaharas
Jan 20, 2014 06:57 PM
93Accord2.2
Nov 7, 2013 07:10 AM
03Sleeper
Jun 11, 2008 08:54 PM
eshop8316
Apr 22, 2008 07:15 PM
EXLV6
Jun 27, 2007 03:57 PM
