1996 2.2 lx 5 speed please help!!!! Desperate
Old Feb 6, 2013 | 08:28 PM
  #41
accord6266's Avatar
Its square and grey
Old Feb 6, 2013 | 11:43 PM
  #42
pmb1903's Avatar
The main relay? I know where that is and my fuel pump is coming on and priming. Is there another one down there your talking about accord6266
Old Feb 7, 2013 | 01:04 AM
  #43
Wazari's Avatar
Originally Posted by pmb1903
And ae they built into the sprocket? Can they go bad but how are they read by the cyp sensor if that's down by the crank and the cyp sensor itselft is built into the distributor housing? Idk I guess I'm jut curious asking all I can lol knowledge is power lol
I'm not talking about the CYP (cylinder position sensor) in the distributor, I'm talking about the CKPS (crankshaft position sensor) that's behind the crank pulley. I'm pretty sure it's mounted to the oil pump housing.
Attached Thumbnails 1996 2.2 lx 5 speed please help!!!! Desperate-tdc-ckp-sensor.jpg
Old Feb 7, 2013 | 02:37 AM
  #44
accord6266's Avatar
my car had the same problem all i did was switch it and wala it started rite up ..i got a 96 4dr
{plus i take it out every nite so they wont be able to start.it will turn over but wont start}
Old Feb 7, 2013 | 02:43 AM
  #45
accord6266's Avatar
im sorry i ddnt c this... not at all man did you try giving it a diag to c what comes up?
Old Feb 7, 2013 | 06:50 AM
  #46
pmb1903's Avatar
I bought a brand new one before I had the new head put on and yes
I have a cel on and its a P1382 whjich means cylinder position sensor no signal. Is there a different kind of diagnostic that can be ran besides the obd2 port if so please tell me
Old Feb 7, 2013 | 07:49 AM
  #47
The main relay might have been a distraction. If the fuel pump always primes properly, and your problem has already been narrowed down to spark (only #3 gets spark) then I don't think the main relay is involved here.
The "pulser" & "reluctor" are just the type of sensor that is the CKP, CYP, & TDC sensors. It's just a kind of miniature "metal-detector" with some metal tabs or teeth that pass close by to generate a signal.
Old Feb 7, 2013 | 08:15 AM
  #48
Roader's Avatar
Measure the TDC & CKP sensor resistance at the plug by the timing cover and again at the ECU connectors. This thread might be helpful:
1997 Accord shutting off no start with cel
...and this thread, post #11 showing the FSM diagnostics page:
honda-tech(dot)com/showthread.php?t=3016441
Old Apr 1, 2013 | 10:36 PM
  #49
98CL2.3's Avatar
All of that and the thread just dies!?!? What happened? Are we to assume that you junked the car?
Old Apr 2, 2013 | 07:14 AM
  #50
Happens all the time. They probably fix the car but never come back & tell us the end of the story.
