1996 Accord 2.2 transmission problem
Old Feb 10, 2013 | 08:52 AM
onempty's Avatar
Angry 1996 Accord 2.2 transmission problem
Need help!My tranny went out at 137,00mi.If buying a used one do I have to buy a computer for the tranny to match the tranny?Also does the used tranny and computer vin numbers need match?Thanks in Advance,
Old Feb 10, 2013 | 09:08 AM
If you find a transmission matching your generation and model (EX, LX) you should not have problems.
Old Feb 10, 2013 | 09:15 AM
No you do not need a new computer assuming the transmission is the same as the stock one.
Check out car-part.com to find used transmissions close to you.
Old Feb 10, 2013 | 09:45 AM
Roader's Avatar
Any auto from an F or H series engine will bolt up and work fine with your computer. '94 - '97 is a direct swap. I've read that a '90 - '93 trans requires one of the mounting studs to be swapped out to mount on a 5th gen chassis but otherwise it's a straight swap. There are differences in gear ratios:
cb7tuner(dot)com/vbb/showthread.php?t=37839
Old Feb 10, 2013 | 02:33 PM
Stay away from 1998 & newer for a transmission.
- Completely different control scheme that's more computer controlled.
- These are known to be more "fragile".
Old Feb 17, 2013 | 08:26 AM
onempty's Avatar
Smile Tranny Problem
Thanks guys for your helpful information & advice!
drumdoctor
Jun 27, 2014 01:36 AM
Neptun3
Jun 22, 2013 09:44 AM
Tandem2
Apr 8, 2012 10:14 PM
ChuckBlack77
Mar 29, 2012 05:42 PM
sskautos
Apr 27, 2011 06:26 AM
