1996 accord f22 cranks no start
Old Apr 2, 2013 | 04:04 PM
DeathByFox's Avatar
Default 1996 accord f22 cranks no start
So I rebuilt the head on my accord. Made sure to keep the timming correct. But when I put everything back together it cranks but it wont start. I also now hear a buzzing noise coming from the steering column? It didn't make that noise before though.
Old Apr 3, 2013 | 10:24 AM
DeathByFox's Avatar
so I went to the crank no start troubleshooting chart. I followed everything it said to do. I have spark I have fuel. the belt is turning the cam. im stuck. the only strange thing is the buzzing from the steering column while cranking....
Old Apr 4, 2013 | 07:34 PM
Re check the main ground on the drivers end of the tb.
How did you verify fuel and spark....Sorry I have to ask but I want to be sure.
Old Apr 4, 2013 | 08:22 PM
XxSikSticksxX's Avatar
Do you know how to check if you set the timing correctly an did you put the head on you're self and if you did did you do the valve adjustment cause you will bend valves
Old Apr 4, 2013 | 08:23 PM
And also make sure you're firing order for the plugs from the distributor to the spark plugs are correct
Old Jun 4, 2013 | 06:20 PM
DeathByFox's Avatar
I verified spark and fuel threw the Honda crank no start diagnosis chart. I have fuel I have spark I set the timing correctly. Now when I start it it makes a buzzing sound from under the dash. im really at wits end with this car.....any help would be appreciated.
Old Jun 4, 2013 | 07:16 PM
Humor us and tell us what you did to determine spark, fuel, and timing were good.
If you're convinced on spark fuel, and timiing, next step is to check engine compression. That's about all that can prevent starting w/ other items in good shape.
Old Jun 4, 2013 | 08:51 PM
X2 on the specifics asked by TexasHonda.
Also, tell us the wire colors going to the map and TPS sensor. Have you tried checking for engine codes?
maverick2k7
Feb 5, 2011 08:59 PM
AbaZ
18
Jul 16, 2008 10:23 PM
LiquidR1
Sep 2, 2007 09:26 PM
SpanishN00b
Jul 29, 2007 07:11 PM
thomks
Aug 15, 2006 06:43 PM
