1996 Accord V6 SRS Computer replacement
Old Jun 5, 2005 | 01:37 PM
tkbalt
Default 1996 Accord V6 SRS Computer replacement
We have a 1996 Accord V6 (85K miles) and the SRS light is on. Dealer indicates the SRS computer needs to be replaced at a cost of $700.
We have had the car since new and plan to keep it. I hate dropping $700 into this computer if there are alternatives available. Used? Remanufactured?
Have seen a few on Ebay - but not sure where to locate the module and verify the correct part number.
Any thoughts on how I can get this done without buying a new unit?
Old Jun 12, 2005 | 11:58 AM
tkbalt
Default RE: 1996 Accord V6 SRS Computer replacement
bump - can anybody assist?
Old Sep 25, 2006 | 08:29 PM
adbraz's Avatar
ORIGINAL: tkbalt
id get one at ebay or send the module to repair http://www.airbags-oem.com/
Old Sep 25, 2006 | 09:10 PM
hondadude's Avatar
Salvage yard unit might work if it hasn't been activated, make sure they will warranty it. I think there are 2 manufacturers.
The unit is located on the center 'hump' behind the radio. Disconnect the battery after you get your radio code, then you can dash dive down by the gas pedal to remove the torque screws that hold it in place. Also dive in on the passenger side to check for more bolts there.
Old Sep 25, 2006 | 09:13 PM
sir_nasty's Avatar
did they say what was wrong with it? no chance that it can just be reset or anything?
uraceulose
Aug 4, 2014 07:12 AM
PepeLePew
Jun 4, 2012 10:00 AM
Rob_KCMO
Apr 18, 2010 12:05 AM
my350z8
Oct 19, 2007 12:10 PM
alvinr
Dec 16, 2006 11:28 PM
