1996 Honda Accord LX4 cylinder heater not blowing hot air
Old Sep 29, 2019 | 11:56 AM
Laurie's Avatar
Default 1996 Honda Accord LX4 cylinder heater not blowing hot air
Does anyone know if a heater that's blowing only cold air is due to the upstream sensor not working
Old Sep 29, 2019 | 12:08 PM
If the heater is only blowing cold air, it is usually due to a broken heater control valve or cable. But, also can be due to a clogged heater core. See this other thread for the location of the valve (under the hood, near the back). See if it moves when you select heat. You can also manually move the lever in the engine compartment and see if you get heat.
https://www.hondaaccordforum.com/for...81/#post366033
Old Sep 30, 2019 | 03:32 PM
The Toecutter's Avatar
Or even possibly a stuck open thermostat.
jescovi
Aug 6, 2019 04:11 PM
rob bruens
Feb 25, 2011 05:41 PM
BHoward711
Apr 12, 2010 08:57 PM
dsgammo
Nov 12, 2008 07:59 AM
soldierforchrist2
Dec 4, 2005 11:34 PM
