1996 honda civic 4cyl sohc
Old Feb 18, 2022 | 03:40 PM
BassShot's Avatar
Default 1996 honda civic 4cyl sohc
Car stalled and wouldnt start back up for a minute (didnt hear fuel pump pressurise when tried to restart. Car keeps trieing to stall first 10 minutes when starting for day but after that runs fine have replaces few parts dont know what to fix
replaced
cap
rotor
spark plug
spark plug wires
fuel filter
did have fuel filter tightened to far but did loosen it any ideas what to replace feel retarded for keep fixing wrong parts, dont get me wrong love working on it but feel retarded and getting a lil upset
Old Feb 19, 2022 | 04:24 AM
Is the check engine light turning on? The 96 obd2 connector is behind the ashtray. Try to have codes read to possibly provide direction on troubleshooting.
Old Feb 19, 2022 | 07:00 AM
BassShot's Avatar
ive read the obd codes the only ones i got were an 02 sensor sensi did get a cyl 2 & 4 misfire but since ive reset it i havent gotten those
Old Feb 19, 2022 | 09:33 AM
Just realized you have a Civic. Ignore the location of the OBD2 connector. Do you have a scanner that can read any live data? See if you have a misfire counter for each cylinder.
What was the actual obd2 code(s) you read?
Old Feb 20, 2022 | 06:38 AM
BassShot's Avatar
One was p0135 c0848 p0304 p0302 c0313 c2b10
Old Feb 20, 2022 | 09:44 AM
Since the engine runs fine after the car warms up, then items like the distributor and spark plugs can be ruled out, because you would have the problem all of the time.
Did you do any work on your car not long before the engine stalled? Any chance you filled up the gas tank right before this happened?
Paulen Swope
Sep 6, 2016 11:39 AM
usafshelley
Jun 1, 2011 10:46 PM
sashkarad
Jul 6, 2009 06:27 PM
old_phart
Mar 13, 2008 07:01 PM
guster900
Jan 28, 2007 05:36 PM
