1997 accord 2.2 a/t idles rough but drives smooth
Old Jun 22, 2025 | 08:30 PM
observant1's Avatar
Common Causes and Troubleshooting Steps:
  • Spark Plugs and Ignition Coils: Start by checking the spark plugs and ignition coils for wear, damage, or corrosion. Replace them if necessary.
  • Distributor (if applicable): If your Honda has a distributor, the ignitor module inside might be faulty. Inspect and potentially replace it.
  • Valve Adjustment: Older Honda engines, especially those with overhead valves, may need a valve adjustment. If the valves are not properly adjusted, it can cause misfires.
  • Cylinder Compression: Low cylinder compression can also cause misfires. A compression test can help determine if there are issues with the pistons, rings, or cylinder head.
  • Timing Belt/Chain: Check the timing belt or chain for proper alignment. If it's off, it can lead to misfires.
  • Fuel Injectors: Faulty fuel injectors can also cause misfires.
Old Jun 22, 2025 | 08:34 PM
Tron4123's Avatar
If you reread my description your see everything Ive done including spark plugs, and wires distributor cap and rotor new fuel tank fuel pump fuel filter im waiting on injector rebuild kits new timing belt water pump cam and crank sensor valve adjustment I've triple checked all the line up points on the timing belt
Old Jun 23, 2025 | 06:17 AM
observant1's Avatar
Sorry. I should have read more. Looks like you have eliminated a great deal. It's probably not your injectors as usually only 1 will act up and the code will indicate that particular cyl. But you never know.
alekth85
Jul 24, 2017 03:58 AM
wannakeepmy94Accord
Jul 1, 2014 07:27 AM
ryan0130
Apr 30, 2011 02:54 PM
r7derek
Feb 27, 2010 06:51 PM
fireballer44
Feb 1, 2007 01:55 AM
