1997 Honda Accord LX Oil leak...Maybe Valve Cover Gasket?????
Old May 26, 2012 | 07:02 PM
B501's Avatar
Default 1997 Honda Accord LX Oil leak...Maybe Valve Cover Gasket?????
I recently purchased a 1997 Accord and oil has been leaking like crazy. I noticed a little piece of plastic hanging out of the Valve Cover. is this the Gasket????? check the pics
Attached Thumbnails 1997 Honda Accord LX Oil leak...Maybe Valve Cover Gasket?????-photo.jpg   1997 Honda Accord LX Oil leak...Maybe Valve Cover Gasket?????-photo-1-.jpg
Old May 26, 2012 | 08:21 PM
moey's Avatar
Yes theres a valve cover gasket its fairly easy to replace I did mine in about a hour on my 96. If you go to a Honda dealer you can buy a kit which will include the gaskets for the spark plug wells and the grommets and valve cover gasket. If I recall correctly its $20-$30, the aftermarket ones are supposedly harder to install and dont fit quite as well but you do save some money. You'll also need some honda bond to put on the end tabs in the diagram.
Attached Thumbnails 1997 Honda Accord LX Oil leak...Maybe Valve Cover Gasket?????-13sv401_e09.jpg
Old May 26, 2012 | 08:25 PM
B501's Avatar
Thanks. I purchased the FEL-PRO VCG kit but i don't have any Honda Bond. Is there anything else the mechanic can use?
Old May 26, 2012 | 08:30 PM
RTV grey
Old May 27, 2012 | 05:28 AM
jerrym's Avatar
Almost A Senior Member
Replaced the valve cover gasket and seals on my 97 Accord a few years ago. Pretty easy job, just don't tighten the cover bolts down to much. The Honda manual calls for 7.2 ft lbs of torque on the bolts.
Old May 27, 2012 | 01:13 PM
GoneHonda's Avatar
this is a big deal! so be cautious
Old May 27, 2012 | 08:28 PM
EXV6NIGHTHAWK's Avatar
My advise is to use a nutdriver (screwdriver with a socket), to tighten the valve cover nuts. You'll have less chance of snapping them, if you don't have a small torque wrench.
ChicagoBob123
Nov 6, 2011 06:22 PM
freezerman
Apr 30, 2009 04:31 PM
reinventingaxlrose
Jun 30, 2008 01:33 PM
thunder_x
Jul 9, 2007 11:57 AM
richomundo
Mar 13, 2007 09:25 PM
