1998 Accord Coupe Starting and then Dying
Old May 26, 2010 | 06:07 AM
Haz750's Avatar
Default 1998 Accord Coupe Starting and then Dying
Hi All,
I have a 1998 V6 Coupe with 113,000 miles and recently it has the annoying habit of losing power and the engine ceasing to run after starting. I then leave it for about 10/15 mins and then it starts normally. There is also a slight rattle when I accelerate as well, but I'm guessing this maybe a loose heatsheild.
I had it serviced in Jan 2010 so can't be any fuel/oil filters as they have been chnaged and I also have an aftermarket induction kit fitted but I have had this fitted for three years with no problems.
I'm guessing it might be a fuel sensor/air mass sensor and at worst case scenario may even be a head gasket that needs to be placed (which I would want).
Any thought's suggestions would be appreciated.
Thanks in advance!
Old May 26, 2010 | 01:51 PM
can you get the car to stall by shaking the key while the engine is running?
Old May 28, 2010 | 10:31 AM
Wicked Pete's Avatar
Does it sputter and die, or just like someone shut off the key? I suspect fuel pressure. I am a Bronco Mechanic, and really have to admit I don't know how you test this on your year Honda. But there are certain physical (Physics) properties that are the same. Let us know how it goes.
Old May 28, 2010 | 12:19 PM
vengeance's Avatar
does is abruptly die or does it spudder then die?
Old Jun 1, 2010 | 05:30 AM
Haz750's Avatar
Hi All,
It tends to start and then 5 seconds after abruptly stops. I checked all the electrics and battery and they are providing ample charge.
I must admit I am stumped as after this it then starts up and then it behaves as normal.
Also when I pull away quickly the handbrake light comes on and then goes out? I am starting to lose my patience a little with it and don't really want to get rid of it.
Thanks to all who have replied.
blackaccord01
May 16, 2014 09:21 PM
DSturch1
Apr 8, 2013 08:11 PM
SolEX01
Aug 10, 2010 05:04 PM
gmcginley
Jul 10, 2009 12:58 PM
garronriec
Sep 2, 2007 03:25 PM
