1998 Accord Floor acceleration, LOUD exhaust, no power. Help?
Old Oct 19, 2011 | 02:55 PM
jfidelh's Avatar
Default 1998 Accord Floor acceleration, LOUD exhaust, no power. Help?
::Symptoms::
~Loud exhaust
~Slow acceleration
~Bad Fuel economy
Hey guys, So i really need some help troubleshooting my problem.
I recently dropped the oil pan on my car to weld up an oil return hole. That part of the project went well. I then put the oil pan back on and that was a success.
What I noticed while driving it the day after this project was when I would try to accelerate, my exhaust would sound really loud, too loud, really deep and it would accelerate really slow.
I am thinking maybe I have an exhaust leak? I somewhat researched the problem and I read online that an exhaust leak wouldnt cause that.
I did have to remove the downpipe to be able to remove the oil pan. So I thought maybe I didnt put it back on right. I literally took off the downpipe (4) different times and bought a new gasket for in between the exhaust manifold and downpipe.
I also replaced my plug wires as well because the metal casing on #(3) that plugs into the distributor had broken off. I thought this was my problem at first but when that didnt work I resorted to taking off the downpipe and putting it back in.
If the oil pan had a leak somewhere would that cause my symptoms?
Old Oct 19, 2011 | 06:32 PM
piggylover1985's Avatar
Sure a big exhaust leak will cause it to loose power, and will sound loud, it needs some back pressure to run properly.
Old Oct 19, 2011 | 07:01 PM
jfidelh's Avatar
The problem is, I cant seem to fix the exhaust leak!
Old Oct 26, 2011 | 04:53 AM
jfidelh's Avatar
Does a bad catalytic converter sound like it might be causing the issue??
Old Oct 26, 2011 | 03:20 PM
jfidelh's Avatar
Took off my cat and sure enough,,, the "honeycomb" type stuff was broken in bits and pieces -_______-
Old Nov 7, 2011 | 01:22 AM
jfidelh's Avatar
It was the spark plug wires not in right even though I bought brand new ones i didnt install them right.
JeffB
Mar 8, 2012 12:09 AM
techjohnny
Jan 15, 2011 09:32 AM
thunder_x
Sep 7, 2007 01:09 PM
pyaarawala
Jun 17, 2007 01:38 AM
