1998 accord- front sway bar links
Old Oct 18, 2019 | 12:47 PM
rockhoundrob's Avatar
Default 1998 accord- front sway bar links
I plan to change the sway bar linkages on the front of my daughter's car. The Chilton manual says to tighten the nut to 14 ft lbs.
That doesn't look right to me. I would have thought it would be around 30 Ft. Lbs.
Can anyone confirm?
Old Oct 18, 2019 | 01:06 PM
Seanjordan20's Avatar
Tighten them how you want. I've never torqued links and haven had an issue.
Old Oct 18, 2019 | 01:42 PM
The Toecutter's Avatar
Agreed. I used the Moog problem solver ends from Rock Auto. Much easier to work with, and are greaseable.
Old Oct 18, 2019 | 04:17 PM
OK.. guess I'll go with 30 ft lbs then... Thanks!!
Old Oct 22, 2019 | 09:39 AM
Well, after taking the links off and putting the new ones on, I put on a torque wrench when tightening the new nuts.
I actually went up to 40-45 ft lbs before I felt it was tight enough...
No way is less than 30 ft lbs enough...
Old Oct 23, 2019 | 02:09 PM
29 lb-ft from the shop manual. Step 5 item A.
Cavell
Nov 12, 2017 05:15 PM
BuntinBoy9
Nov 5, 2007 09:16 AM
ckebottle
Oct 12, 2007 11:41 PM
maro
May 25, 2007 03:36 PM
ArcticHonda
Dec 13, 2006 11:49 PM
