1998 Acord Air Conditioning Problem
Old May 25, 2010 | 08:09 AM
regmike's Avatar
Default 1998 Acord Air Conditioning Problem
Variation in the coolness of the air. Some days it works fine, then it blows warm and vice versa. Since it blows cool some times I assume the charge is adequate. Any ideas - temperature sensors, etc. - I should look for and where they are located?
Thanks!
Old May 25, 2010 | 10:51 AM
Measure system pressures anyway (high & low). There's pressure switches that shut off the compressor when (for example) the pressure is too low. If your refrigerant charge is marginal, it's possible that a pressure switch is sometimes allowing it to run, sometimes not.
shoot22
Feb 2, 2019 05:40 AM
erader00
Aug 2, 2013 05:00 PM
maestro1024
May 29, 2012 11:38 AM
caliass
Jun 19, 2010 06:58 PM
tedog1985
Jun 25, 2007 04:53 PM
