1998 cv axle rebuild
Old May 6, 2024 | 10:04 PM
Matwilber's Avatar
Default 1998 cv axle rebuild
I took the right hand side axle out from under my 1998 accord SiR-T, it has a torn outer boot. Long story short I couldn’t get the outer part of the axle appart and the inner boot was cracked up, so I decided to change that one as well and took the back end of the axle appart. When I slid off the inner end, I took off the bearings and cleaned everything up and put it all back together with new boots. The bearings were siting on rectangular spacers, I didn’t notice what side the were on (the bearings don’t sit in the middle of the spacers). I reassembled the axle without really thinking about the orientation of the bearings. Anyone have a diagram of these to help me make sure I didn’t put them in upside down?
I drew a rough picture of the bearings and the two possible ways of re-assembly. I hope some of this gibberish means something to you guys!
thanks for you help!
for your trouble here’s the car on prelude wheels with winter tires
Old May 7, 2024 | 12:31 PM
Is the grey part in your drawing the roller bearing that has a base attached like a tophat? I think the orientation is the 4 o'clock orientation.
Google 44310-S3X-300 to see if the images are what you are asking about. I believe these spacers are for manual transmission CV joints.
Old May 7, 2024 | 12:48 PM
Matwilber's Avatar
a million thank you’s for the google search. With it I found this :
Josh Doebler
Oct 26, 2019 10:41 AM
xterrestrial
Sep 21, 2017 08:41 AM
f22ax2
May 29, 2014 05:07 PM
donauaj
Mar 27, 2011 09:59 PM
vonmadthane
Mar 10, 2009 03:24 PM
