1998 Honda Accord LX(valves adjustments)
Old Sep 10, 2014 | 01:14 PM
rockhoundrob's Avatar
Default 1998 Honda Accord LX(valves adjustments)
My daughter has a 1998 Honda Accord LX (170,000 miles, V-Tech, 4-cyl, automatic)
In the manual, it recommends having the valves adjusted every 50,000 miles? I have no idea when the last adjustment was done. I bought it at 150,000 miles.
Is this critical? It gets 250 miles per tank (all city driving). How hard is it to do it yourself? I do work on cars, but it's been mostly starter, brakes, alt., radiators, window regulators, dist, caps, wheel bearings, CV axles, etc...
Is this something I can do myself if i read the manual carefully?
Any other advice or pointers to tell if the valves need to be adjusted?
Old Sep 10, 2014 | 03:58 PM
Valves usually loosen and get a bit noisy on cold engine. If valve cover gaskets (rim and spark plug tube seals) have never been replaced, you could combine that job w/ checking the valve/rocker arm clearances.
Suggest getting a shop manual to review the entire procedure, but turn cylinder to be inspected to TDC and check valve top to rocker arm clearances. Intakes are 0.010-inch and exhaust 0.012-inch clearance.
On Honda V6's the valves are known to tighten. How? Only way I see is for seats to collapse, but apparently it happens. Never heard of valves getting tighter on 4-cyl, but it may be possible.
Old Sep 11, 2014 | 08:01 AM
YeuEmMaiMai's Avatar
when you do adjust your valves, the engine is COLD.
Hot Brass
Canada, Over Seas & Elsewhere
Aug 6, 2014 12:00 PM
Carrameow
Feb 6, 2014 07:17 AM
HiMilesJ
Dec 23, 2012 06:05 PM
jerrym
Jan 2, 2012 08:56 AM
