1999 Accord EX 4cy, only the driver side wiper works
I have a 1999 accord and the passenger side wiper isn't working. Driver side works fine on all speeds. The passenger side slightly moves but its more like a flinch. Is the motor bad? The passenger side didn't seem to be loose
Please update us as to your findings.
There's only one motor, so that would make both sides quit together.
There's a linkage connecting the wipers to one another. That has a kind of push-rod that has gotten loose & caused what you see.
But first, remove the center nut at the pivot point of the passenger-side. Is it possible the wiper arm isn't "loose" but it can spin on its shaft? Pull it off, reposition, then tighten. If that's no good you'll have to get into the linkage below.
southbronx, What usually happens in this situation is that the arm has come loose and filled the tiny grooves on the pivot/post with aluminum. If you replace the arm without cleaning those splines you will likely have the same problem in a short time...use a small ,sharp pick to scrape them clean. Many times the same arm works fine after the splines are cleaned
jza240sx
Apr 30, 2013 04:14 PM
Groundhog
Feb 20, 2012 07:36 AM
jblackwe1969
DIY Answers.
Jul 8, 2010 12:04 PM
Hondapt
Jan 14, 2009 11:58 PM
silverstreak89
Aug 16, 2006 02:17 AM
