1999 Accord O2 sensor replaced light still on?
Old May 14, 2012 | 10:49 AM
Figmant's Avatar
Default 1999 Accord O2 sensor replaced light still on?
I have a 1999 Honda Accord which had the Check Engine Light come on. I live in NY so it will not pass inspection with the light on. I had AutoZone pull the code (i can't remember the exact code) but it was the Oxygen Sensor. I replaced both Oxygen Sensors (upstream and downstream with Denso) I also replaced the Mass Airflow Sensor, spark plugs and air filter. I reset the codes and the light went out, but when I start the car within 30 secs the light is back on. The code is the same Oxygen Sensor. I have checked the plugs, mounts, wires and used the O2 socket for install and removal. I have driven the car around 20-30 miles and reset the code, but it comes back on almost immediately with the Oxygen Code. Do I need to drive the car 100-200 miles to get it to reset? What am I missing here? I also heard there is a way to reset/bypass the code so that it will pass the State monitoring at the time of inspection. Sounds like they reset the code and they inspect the car while the computer is just monitoring the sensors prior to tripping the code. Open for any help I can get on this issue.
Old May 14, 2012 | 11:00 AM
Get the trouble code and post it, as that will give more clues to narrow down the problem.
Old May 14, 2012 | 01:35 PM
Dr. Drivability's Avatar
troubleshooting is more than just getting a code and replacing parts. also, why did you replace the maf? just for grins & giggles?
Old May 14, 2012 | 02:00 PM
IIRC, 1999 Accord didn't have MAF sensor, only a MAP sensor. I believe the MAF sensor started appearing on the 2003 - current Accords.
Old May 14, 2012 | 02:47 PM
you're right redbull, he must mean "map" sensor???
Old May 14, 2012 | 02:54 PM
Yep, he must mean MAP. I seen from some of your previous posts (e.g., access to ISIS, etc.), you're an actual Honda tech?
Old May 14, 2012 | 03:11 PM
somthing like that
Old May 14, 2012 | 05:00 PM
LO CORD's Avatar
My suggestion is unhook the battery--let the computer reset after a few minutes re-connect the battery--see if that clears the code....make sure and test drive it around the block or so to make sure the reset took.
Old May 16, 2012 | 06:45 PM
1999 codes can be cleared by pulling the #13 fuse in the right-side fusebox - located at the right-side end of the dashboard, near the right-front door hinges. Or pull the negative battery cable.
Beginning in 2003 the non-volatile memory can't be cleared without a code reader.
JOE.G
Feb 3, 2019 07:42 AM
holiday
Jan 17, 2012 01:38 PM
94LxAccordCoupe
Jan 14, 2012 01:57 AM
jackfast
Feb 13, 2011 05:43 AM
jmtdaddy
Oct 20, 2009 06:00 PM
