1999 Accord Transmission Erratic Shifting
Old Dec 11, 2012 | 06:38 PM
unaffiliated1's Avatar
Default 1999 Accord Transmission Erratic Shifting
Ok, I recently purchased a 1999 Honda Accord LX, 4cyl. automatic...Knowing there was a transmission problem...I limp'd it home, while trans acts like it switches to neutral then regains traction after some time, also down shifts hard and erratic when slowing...I noticed there A LOT of trans problems in this era of Honda...I did drain the fluid and install 3 qts of Honda ATF DW-1 and also cleaned the soleniod screens located below battery tray...I have a 96 Accord that I just love, no problems whatsoever...Should I just drop the trans and repair/replace or is there a possibility it can be fixed w/o removal???? There were some codes stored before I recleared...One a gear ratio code, one a third gear soleniod code...Thanks in advance...
Old Dec 11, 2012 | 06:53 PM
Post the actual codes you are getting. They start with the letter P and have four numbers, like P1234.
Old Dec 11, 2012 | 09:14 PM
I'll have to retrieve data again, I think they were in the 700's...P0730 and P0751 possibly...I'll get back soon...
Old Dec 13, 2012 | 10:57 AM
OK, codes are p0700,p0740 and p0170...
Old Dec 13, 2012 | 10:59 AM
Its actually doing better since the fluid change, it is driveable, just a little quirky at times...
Old Dec 13, 2012 | 11:07 AM
Silver6gen's Avatar
Thats good to hear, I would be gentle on her though. This is not a good sign.
Rilex
Sep 13, 2013 07:35 PM
rsttoole
Apr 6, 2013 03:46 PM
matias_25
Oct 8, 2011 06:49 AM
echolsautosales
Mar 16, 2006 11:07 AM
cbriley3
Oct 23, 2005 11:04 PM
