1999 Honda Accord 3.0L V-6 acting up but doesn't die!!!!!!!!!!!!
Old Dec 25, 2019 | 02:29 PM
  #41
Seanjordan20's Avatar
There's 2 spots to clean. Did you clean the passage on the engine also. Was yours clogged? As long as you can see through it it's clean.
Old Dec 25, 2019 | 02:31 PM
  #42
goosemasterkl's Avatar
Where can you see thru at? From the hole to the throttle body opening? I cleaned the one on the engine also.
Old Dec 25, 2019 | 02:34 PM
  #43
Did you check to make sure the egr was working? Spray carb cleaner and let it soak. You should see the cleaner going through
TSB 99-085
Old Dec 25, 2019 | 02:36 PM
  #44
What made you put a new TPS on
Old Dec 25, 2019 | 02:50 PM
  #45
I replaced the map sensor so I went ahead and changed the tps also. I'll check to see if the egr is opening before I take the plenum back off to re-clean the ports. Did you say use the pink wire to test the egr?
Old Dec 25, 2019 | 02:55 PM
  #46
Yes the pink wire. What brand tps did you use.
Old Dec 25, 2019 | 03:34 PM
  #47
Do you just ground it and go from the positive battery post to the pink wire?
Old Dec 25, 2019 | 03:41 PM
  #48
Keep the cable plugged in. Back prob the pink wire to the positive. The egr should open.
Old Dec 26, 2019 | 02:31 PM
  #49
Do you just back probe the pink wire and jumper it to the positive post on the battery? Do I have to unbolt it from the car? Does the ignition need to be turned on?
Old Dec 26, 2019 | 02:51 PM
  #50
Take it off because you will not be able to see underneath to see it open. Jump the pink to the positive lead by back probing.
