1999 Honda Accord 3.0L V-6 acting up but doesn't die!!!!!!!!!!!!
Old Dec 26, 2019 | 02:54 PM
  #51
goosemasterkl's Avatar
I couldn't get it to do anything backprobing the pink wire and hooking it to positive battery post. I took it loose from the car and when I turn the ignition on and off the plunger goes in and out on the egr.
Old Dec 26, 2019 | 03:00 PM
  #52
Does this mean now I need to take the plenum back off and reclean the passages?
Old Dec 26, 2019 | 03:05 PM
  #53
Seanjordan20's Avatar
If you have cleaned the egr holes with card cleaner and all passage holes then yes. The code you have if for a blockage
Old Dec 26, 2019 | 03:09 PM
  #54
Do you have a p0401 code also? Try unplugging the egr valve and running the car?
Old Dec 26, 2019 | 03:11 PM
  #55
I haven't cleaned the egr valve itself But with the plunger moving in and out when I turn the ignition off and on don't that indicates the egr is working or could it be stopped up internally itself?
Old Dec 26, 2019 | 03:13 PM
  #56
No; I just have a p1491.
Old Dec 26, 2019 | 03:32 PM
  #57
I don't have a p0401 with the egr unplugged. What's up with that?
Old Dec 26, 2019 | 04:00 PM
  #58
So with the egr unplugged you coded cleared or you still have the 91 code?
Old Dec 26, 2019 | 04:03 PM
  #59
It's not showing any codes now with the egr unplugged.
Old Dec 26, 2019 | 04:37 PM
  #60
Ok I would do more tests on a better diag tool but looks like you are having a intermittent issue with the egr. What brand position sensor did you put in.
