2.7 motor mounts
Old Jan 6, 2013 | 07:17 PM
snicrep's Avatar
Default 2.7 motor mounts
Im sure I have at least one bad mm. But I want to change them one at a time. Which is the one that goes out the most or first. I get some vibration on accelleration and a bit of a bump when in 2nd gear and letting off the gas. The left and right ones look intact. I tried having someone hold the brake and put it in drive through reverse but coulldnt see anything obvious.
Old Jan 7, 2013 | 05:37 AM
Thump when you let off implies the tension side mount may be damaged; slack under load allows engine to relax and cause noise. When engine is in D and brake held w/ 1500 rpm throttle, one mount is under compression and other tension.
mpanelli
Nov 9, 2014 08:39 AM
RSM93HONDA
Jan 24, 2007 01:08 PM
jim97gst
Dec 7, 2006 01:22 PM
abelh7
May 28, 2006 04:31 PM
nixalot
May 16, 2006 05:22 PM
