2000 2.3 with ABS light on CEL 53-1
Old Mar 26, 2019 | 06:09 PM
Jet sitter's Avatar
Default 2000 2.3 with ABS light on CEL 53-1
My ABS light came on today. Checked code and it's the 53-1 ABS module. I looked at the fuse and there were dark marks (arching) on the pins, but the fuse was still good. Replaced it with another 7.5 amp fuse. Light still on, pulled both electrical connectors sprayed electric cleaner on the pins and receivers, CEL remained on. I checked google and the most common cause of that CEL is the electric motor on the pump. Has anyone had any experience with this problem? Appreciate your expertise, thanks. If you guys agree with google, I'm thinking of pulling the motor and cleaning the armature and installing new brushes.
Old Mar 27, 2019 | 08:19 AM
Be careful you aren't finding something about earlier versions of the ABS. Not sure if you can do anything like dismantle & clean the ABS motor in 6th-gen cars.
Old Mar 27, 2019 | 09:03 AM
Jet sitter's Avatar
Thanks Jim! You are probably correct. I may just let the ABS remain on, I don't really need it anyway.
Old Mar 27, 2019 | 09:58 AM
Jet sitter's Avatar
After pondering this situation for the past two days, I found the perfect solution. A short piece of black electrical tape placed strategically over the light. Works like a charm!
joepeterson56
Dec 5, 2015 12:45 PM
fahad
Dec 31, 2013 07:47 AM
93Accord2.2
Nov 7, 2013 07:10 AM
firefighter44
May 8, 2012 06:10 PM
thelandlordsmm
Aug 17, 2009 08:48 AM
