2000 Accord occasional hot start problem
Old Jan 12, 2013 | 09:00 PM
jvdlcr125's Avatar
Default 2000 Accord occasional hot start problem
Occasionally, if I try to start my car after driving for a while, it won't start and I hear a single click (not like the multiple clicks of a dead battery). I read somewhere that this is due to a connection problem in the main relay but I'm not sure because it still starts when jumped. There is some corrosion on the battery connections but I don't think that would cause the problem to only happen after the car has been running. I need to fix this ASAP so any help would be much appreciated.
Old Jan 12, 2013 | 11:15 PM
Does the starter spin the engine at all? Or does nothing happen when you hear the click?
Old Jan 13, 2013 | 11:23 AM
Is your Accord a 4 or 6 cylinder?
Here is a Honda technical service bulletin for the Accord V6:
Honda TSB 00-024
Old Jan 13, 2013 | 11:37 AM
If the starter doesn't spin the engine, then its not related to the main relay.
You might have loose/dirty/corroded battery connections, maybe even at the other ends of the battery cables.
norville
Jan 30, 2015 05:14 AM
93Accord2.2
Aug 30, 2013 04:51 PM
gmattutorsam
Mar 28, 2013 04:58 PM
faosh
Jan 31, 2012 01:35 PM
tom60016
Jul 2, 2010 08:49 AM
