2000 Accord - Replaced PCM
Old Apr 1, 2011 | 04:01 PM
BruceHunt's Avatar
Default 2000 Accord - Replaced PCM
I would sure like a bite of advice. I have sent in the PCM out of this vehicle. It was tested, fixed and sent back. I installed it as directed and started the vehicle. It started fine but when put in to gear, it started flashing the D4 and I pulled the P1607 code. I called and talked to the company and they say they will replace the module but first want me to make sure that this is not being caused by the "PCU or TCM". Your thoughts on this?
Old Apr 1, 2011 | 04:38 PM
You accord has only one control unit for the engine and transmission. It is called a PCM. Honda started using a combined unit when the went to OBD2 in 1996 (or 1995 V6).
Was this the error code that you had when you first sent in the PCM?
Old Apr 1, 2011 | 04:43 PM
BruceHunt's Avatar
No, it was a p1705 code and it did have a bad shift position sensor that was replaced. The company said that they replaced some capacitors in the unit.
Old Apr 1, 2011 | 04:54 PM
I think that code is for a bad PCM, so you should send back the control unit to get fixed.
Old Apr 1, 2011 | 04:58 PM
BruceHunt's Avatar
That is exactly what it is telling me. It says there is a fault in bank A. Thanks for responding. You guys are great!
Kevin Slybacon
Dec 31, 2012 05:33 PM
vtorre61
Oct 2, 2012 09:16 PM
ssuh
Mar 27, 2012 08:10 AM
jeffk14
Oct 21, 2011 11:32 AM
