2000 accord shifter problem
I have a 2000 accord dx mt 2dr. I can't shift into gear, it feels like something is blocking ever gear. The only time I could put it into gear is before I started the engine, but when I do that, the car would start moving while I still have the clutch down with the brake released and no stepping on gas. I have no clue what the problem is buti I've been looking everywhere to get a better idea. I thought it was something to do the the clutch fluid because the reservoir was empty but after bleeding it and refilling, nothing changed. I'm pretty stupid when it comes to cars but I'm trying to learn but with out the knowledge, this is just frustrating. Anyone have any idea that would help at all?
It sounds like you might still have air in the clutch system. If the slave is leaking it can also cause issues....not only with bleeding the system but in proper operation.
Inspect the slave cyl, pull the "boot" back and see if there is fluid inside there.
afghandragon45
Dec 31, 2007 07:08 PM
