2000 accord turns over won't run
Old Mar 5, 2021 | 05:51 PM
Tkwagon's Avatar
Default 2000 accord turns over won't run
2000 accord ex 5 speed . No check engine light , no immobilizer light , no main relay click. Turns over won't run. I've checked grounds in the engine bay. I've checked all necessary fuses. I bought this car for my kid thinking it was a simple fix and right now we are no closer to it being fixed. I'm thinking maybe a bad ground. Maybe bad ecm? Maybe a bad main relay? Any help will be a blessing. I have the basic tools and usually I'm pretty good with a honda. Thanks in advance.
Old Mar 5, 2021 | 07:45 PM
When you turn the key to the II position and do not try to start the car, does the check engine light turn on for about 2 seconds to do a bulb check?
Do you have a scanner/bluetooth reader to get codes?
Old Mar 8, 2021 | 03:35 PM
I think the immobilizer lamp (green key) also comes on for 2 seconds during the bulb-check. Does it do that?
Old Mar 8, 2021 | 05:49 PM
Seanjordan20's Avatar
So it cranks but doesn't start. Is the pump priming on number II. If not get some starter fluid and spray it in the throttle to see if you can get it to start. If it starts replace your fuel pump main relay. It under the steering wheel with a brown harness connected to it. These are notorious at this age.
MikeStarkk
Jun 26, 2018 11:16 AM
Shanka
Apr 12, 2012 07:34 AM
crazymikeyo5
May 5, 2008 09:23 AM
90 accord lx
Sep 4, 2007 10:58 PM
99cummins
Jun 25, 2007 09:59 AM
