2000 EX Coupe- Power Seat Height inop
Old Nov 25, 2010 | 07:36 AM
beberle's Avatar
Default 2000 EX Coupe- Power Seat Height inop
I just purchased a 2k Accord EX coupe; the driver's seat power height adjustment doesn't work. I can't hear any motor noises when I press the switch up or down. I checked the fuse under the hood. Any ideas?
thx,
Brian
Old Nov 27, 2010 | 01:06 PM
Additional fuses? There's fuseboxes in both ends of the dashboard. Open the doors & look alongside the door hinges.
Possible a rear-seat passenger kicked under the seat & unplugged some wires?
Old Dec 10, 2010 | 08:17 PM
beberle's Avatar
Default Blown Fuse
Sure enough, there are two 20amp fuses for power seats on the passenger's side dash. One is labeled power-recline, the other was fore-aft. The recline fuse was blown. I only have power height and everything else is manual, so I took the fuse out of the fore-aft and put it into the recline slot. Bingo! Seat works like a charm.
Old Dec 11, 2010 | 12:37 PM
kingofudupi's Avatar
Hi there:
Can I ask you a favour:
Can you check to see if this works on your car. I am having some difficulty fixing my heat.
The climate control unit has a self-diagnosis function:
Running the Self-diagnosis Function:
Turn the ignition switch ON (II), then press the AUTO button and sequentially the OFF button while continuing to press the AUTO button. If there is any abnormality in the system when both buttons are pressed, the temperature indicator will light up the segment (A to N) corresponding to the error. The temperature indicator will then alternate every second between displaying "88" (all segments lit) and the error segment. If there is no abnormality, the segments will not light up.
Let me know how if goes through.
jdenny5
May 12, 2012 06:06 PM
lonberge
Oct 6, 2010 07:36 PM
Bobertsr
Jun 5, 2009 03:58 PM
MALSR
Apr 5, 2008 03:04 PM
detourbeach
May 25, 2006 02:12 PM
